Введение
The Con Board is located under the back cover. This guide will help you remove and replace the Back Con Board from your DJI Phantom 4 Advanced Remote Controller.
Many issues that arise with a DJI Remote Controller are caused by a faulty Back Con Board.
Before beginning, disconnect your drone and power off the remote completely.
Выберете то, что вам нужно
Remove the four screws with a Torx T8 screwdriver to access the back con board.
With tweezers, gently remove the large con board tab.
Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
Peel off the rubber grips to access the screw holes.
Remove the back board and set it aside.
Pull apart the back plastic panel.
Once the back panel is off, you will have access to the motherboard.
Remove each of the three ribbon cables from their tabs by pulling in a horizontal direction away from the socket.
Remove the Back Con Board.
