  1. Remove the four screws with a Torx T8 screwdriver to access the back con board.
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. Remove the three Phillips screws using a Phillips #00 screwdriver.
    • Remove the three Phillips screws using a Phillips #00 screwdriver.
  3. With tweezers, gently remove the large con board tab. Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Peel off the rubber grips to access the screw holes. Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  6. Pull apart the back plastic panel. Recommended tool for this would be the metal spudger, but not required.
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  7. The battery is attached to the back plastic and is towards the bottom the remote.
    • The battery is attached to the back plastic and is towards the bottom the remote.
    • Unplug the cord that is connected to the bottom of the main board.
  8. After the  cord is unplugged, The battery can be removed by lifting upon the plastic cover, which the battery is attached to.
    • After the cord is unplugged, The battery can be removed by lifting upon the plastic cover, which the battery is attached to.
  9. Once the cover is off you can now access the battery
    • Once the cover is off you can now access the battery
Заключение
cade knott
Участник с: 02.10.2018
343 Репутация
Автор 3 руководств
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 8
За 7 дней: 35
За 30 дней: 182
За всё время: 660
