Введение
This guide will show you how to remove and replace the motherboard of the DJI Phantom 4 Advanced Remote Controller.
Before you begin:
- Please make sure to completely power off the the controller prior to any replacements.
- Please read the guide before any replacements in order to familiarize yourself with the process.
Выберете то, что вам нужно
Remove the four screws with a Torx T8 screwdriver to access the back con board.
With tweezers, gently remove the large con board tab.
Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
Peel off the rubber grips to access the screw holes.
Remove the back board and set it aside.
Pull apart the back plastic panel.
Once the back panel is off, you will have access to the motherboard.
Disconnect ribbon tabs 1,2,5,8G, and 3.
Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
Then remove the plugs
2 участников успешно повторили данное руководство.
2 Комментариев
Do you know here can i buy a main board for phantom 4 advanced remote controller?
I would like to know too, can’t find one anywhere
