Введение
Follow this guide to remove the lid on your DJI Spark. The lid needs to be removed to get access to the internals. The propellers and battery need to be taken out first before proceeding with detaching the lid. It is an easy 5-step process that can be done in less than 30 seconds.
Выберете то, что вам нужно
Flip the drone over.
Grip the left and right sides of the battery.
Slide firmly forward until it pops out.
Remove the four 1.5mm Hex screws.
Remove the two 1.5mm Hex screws near the camera head.
Hold the drone so the lid is facing up.
Insert the plastic opening tool into the side of the drone.
Slide the tool around the perimeter until you can lift the top off.
