Введение
This guide is intended to help you replace the battery of the DROCON Ninja DC-014. The drone’s battery provides power to the motors. If you notice reduced performance in flight consider replacing the battery. The battery might need to be replaced if the drone is not charging or is losing battery quickly. You will not need any tools for this guide and there are no difficult steps required. If the battery is swollen take extra care when removing it.
To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
Firmly grasp the battery tab between your thumb and index finger.
Pull the battery away from the drone's body
Еще один человек закончил это руководство.
