Введение
Daewoo DWC LDC1412S Water pump replacement Replacement
Выберете то, что вам нужно
Unscrew the 2 screw that keep the pump in place
You can now gently tear down the pump
Compare your actual pump with the spare you found BEFORE dismounting pipes !
Seems ok ? Let s go forward !
Dismount pipes by pressing steel rings and moving then out of range of the pump
Do this for all pipes connected on the pump
Disconnect both electro pump. Check were is white wire and black wire on each !!
2 участников успешно повторили данное руководство.
