Daewoo KOC-9U0T Lightbulb Replacement
Выберете то, что вам нужно
  1. Daewoo KOC-9U0T Lightbulb Replacement, Lightbulb: шаг 1, изображение 1 из 1
    • Never attempt to change the bulb in a microwave while the microwave is still plugged in or while power is being supplied.
    • Unplug the microwave from any wall outlets or power sources.
  2. Daewoo KOC-9U0T Lightbulb Replacement: шаг 2, изображение 1 из 1
    • Examine your microwave to find the vent on the back of the microwave.
    • On other microwaves, there will be a vent located either in the front, side or bottom of the machine, depending on make, model, and mounting.
  3. Daewoo KOC-9U0T Lightbulb Replacement: шаг 3, изображение 1 из 1
    • Remove the four 20 x 3" screws on the rear side of the microwave using a Phillips #0 screwdriver.
  4. Daewoo KOC-9U0T Lightbulb Replacement: шаг 4, изображение 1 из 1
    • Lift off the service panel of the microwave and set it aside.
    • Do not attempt to change the light bulb from within the microwave's interior; always remove the vent panel and change the light bulb from within.
  5. Daewoo KOC-9U0T Lightbulb Replacement: шаг 5, изображение 1 из 1
    • Locate the box that the halogen light is kept in.
    • Search for the light box that contains the bulb.
  6. Daewoo KOC-9U0T Lightbulb Replacement: шаг 6, изображение 1 из 1
    • Remove the screws that hold the lightbox in place with a Phillips #0 screwdriver.
  7. Daewoo KOC-9U0T Lightbulb Replacement: шаг 7, изображение 1 из 1
    • Unscrew and remove the light bulb from the socket on the lightbox.
    • Replace it with a new light bulb.
    • Screw the lightbox back into place on the frame of the microwave.
  8. Daewoo KOC-9U0T Lightbulb Replacement: шаг 8, изображение 1 из 1
    • Replace the service panel and tighten down the screws.
    • Make sure you tighten the screws hard enough because if it the cover of the microwave is loose, then the radiations can harm your body.
  9. Daewoo KOC-9U0T Lightbulb Replacement: шаг 9, изображение 1 из 1
    • Plug the microwave back in or reset the breaker.
    • You’re ready to see if your microwave has been repaired.
  10. Daewoo KOC-9U0T Lightbulb Replacement: шаг 10, изображение 1 из 1
    • Open the microwave's door to test the new light bulb: If you’ve replaced the bulb correctly and the new bulb is working properly, then the light should go back on when you reopen the microwave’s door!
Заключение
2 участников успешно повторили данное руководство.
Mohammed Reza Doctor
Участник с: 01/26/21
223 Репутация
1 руководство автора
Команда
York University, Team S1-G9, O'Regan Spring 2021 Участник York University, Team S1-G9, O'Regan Spring 2021
YORK-O'REGAN-S21S1G9
1 член
Автор 2 руководств
Один комментарий
This is'nt the KOC-9U0T.... i have the KOC-9U0T model and it looks nothing like the pictures in this guide....
explainet - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 55
За всё время: 2,023
