Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide will show you how to replace the battery in a DOD LS300W Dashcam. For this guide, you will need a tool to open up the dashcam, a soldering iron, and the a little soldering skills. This is a relatively easy repair, but be careful with the soldering iron to not burn yourself.
Thank you for checking out this guide and I hope it helps.
Запчасти
Детали не указаны.
  1. Using an opening tool, pry open the seam on the bottom of the dashcam to open it up. Using an opening tool, pry open the seam on the bottom of the dashcam to open it up. Using an opening tool, pry open the seam on the bottom of the dashcam to open it up.
    • Using an opening tool, pry open the seam on the bottom of the dashcam to open it up.
  2. Notice the connection of + and - on the top left side of the inside of the dashcam. Make note of this as it will be important to remember when you solder on the new battery. Desolder the old battery.  This is a 250mAh.
    • Notice the connection of + and - on the top left side of the inside of the dashcam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. The new battery is 400mAh. and fits just in the battery location. Solder in the new battery. Then place the new battery into the space previously occupied by the old battery.
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  5. Put the dashcam back together.
    • Put the dashcam back together.
    • Charge battery to full level, and your are ready to go.
Заключение
Once again, thank you for checking out this guide and I hope it helped!
2 участников успешно повторили данное руководство.
Pierre
Участник с: 02.04.2013
248 Репутация
Автор 2 руководств
Комментариев: 2
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - Ответить
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 12
За последние 7 дней: 24
За последние 30 дней: 82
За всё время: 4,027
