Введение
This guide will show you how to replace the battery in a DOD LS300W Dash cam. For this guide, you will need a tool to open up the dash cam, a soldering iron, and the a little soldering skills. This is a relatively easy repair, but be careful with the soldering iron to not burn yourself.
Выберете то, что вам нужно
Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
The new battery is 400mAh. and fits just in the battery location.
Solder in the new battery.
Then place the new battery into the space previously occupied by the old battery.
See the difference between old and new battery.
Put the dashcam back together.
Charge the battery to the full level, and you are ready to go.
Once again, thank you for checking out this guide and I hope it helped!
2 участников успешно повторили данное руководство.
2 Комментариев
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
