Dashcam DOD LS300W Battery Replacement
Выберете то, что вам нужно
  1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: шаг 1, изображение 1 из 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: шаг 1, изображение 2 из 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: шаг 1, изображение 3 из 3
    • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
  2. Dashcam DOD LS300W Battery Replacement: шаг 2, изображение 1 из 2 Dashcam DOD LS300W Battery Replacement: шаг 2, изображение 2 из 2
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Dashcam DOD LS300W Battery Replacement: шаг 3, изображение 1 из 3 Dashcam DOD LS300W Battery Replacement: шаг 3, изображение 2 из 3 Dashcam DOD LS300W Battery Replacement: шаг 3, изображение 3 из 3
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  4. Dashcam DOD LS300W Battery Replacement: шаг 4, изображение 1 из 1
    • Put the dashcam back together.
    • Charge the battery to the full level, and you are ready to go.
Заключение
Once again, thank you for checking out this guide and I hope it helped!
2 участников успешно повторили данное руководство.
Pierre
Участник с: 04/02/13
542 Репутация
Автор 3 руководств
2 Комментариев
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - Ответить
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 29
За всё время: 6,352
