De'Longhi EC155 Water Valve Replacement
Выберете то, что вам нужно
  1. De'Longhi EC155 Water Valve Replacement, Water Reservoir: шаг 1, изображение 1 из 2 De'Longhi EC155 Water Valve Replacement, Water Reservoir: шаг 1, изображение 2 из 2
    • Flip open the top panel to reveal water reservoir.
    • Grab the water reservoir by the handle and lift out.
  2. De'Longhi EC155 Water Valve Replacement, Bottom Panel: шаг 2, изображение 1 из 2 De'Longhi EC155 Water Valve Replacement, Bottom Panel: шаг 2, изображение 2 из 2
    • Flip the device on its head.
    • Using the Phillips #2 screwdriver, unscrew the four 12 mm screws found at each corner of the bottom panel.
    • Lift the panel off or flip the device over and let the panel drop out.
  3. De'Longhi EC155 Water Valve Replacement, Top Panel: шаг 3, изображение 1 из 1
    • Before flipping the device, removed the black container and grill.
    • Flip the device on its head, front end facing you.
    • Using the Phillips #2 unscrew the two 52 mm screws found underneath the top portion of the device.
  4. De'Longhi EC155 Water Valve Replacement: шаг 4, изображение 1 из 1
    • Flip the device back to its proper orientation.
    • Using the Phillips #2 screwdriver remove the two 52 mm screws found on the lip next to the reservoir.
  5. De'Longhi EC155 Water Valve Replacement: шаг 5, изображение 1 из 2 De'Longhi EC155 Water Valve Replacement: шаг 5, изображение 2 из 2
    • Insert the two plastic opening tools beneath the top knob.
    • Use the two plastic opening tools as leverage to lift the top knob off.
  6. De'Longhi EC155 Water Valve Replacement: шаг 6, изображение 1 из 1
    • Grasp the lid firmly with both hands.
    • Pull mightily with both hands away from the device.
    • If you hear a slight snapping sound, it is supposed to do that.
  7. De'Longhi EC155 Water Valve Replacement: шаг 7, изображение 1 из 2 De'Longhi EC155 Water Valve Replacement: шаг 7, изображение 2 из 2
    • Use a plastic opening tool to push in the slot on the back panel while lifting.
    • Similarly, reach into where the reservoir used to be and insert a plastic spudger underneath the inside panel.
    • We recommend to not use your fingers for this step because there is a chance they will be pinched.
  8. De'Longhi EC155 Water Valve Replacement: шаг 8, изображение 1 из 2 De'Longhi EC155 Water Valve Replacement: шаг 8, изображение 2 из 2
    • You are now ready to lift the top off.
    • Place one hand near the back, the other at the front, and lift.
    • You may want to lift the front and back individually by pulling one a little off the part before the other. Afterwards, lifting the top off entirely will be easier.
  9. De'Longhi EC155 Water Valve Replacement, Water Valve: шаг 9, изображение 1 из 2 De'Longhi EC155 Water Valve Replacement, Water Valve: шаг 9, изображение 2 из 2
    • Flip the device and remove one end of the tube from the water reservoir hole.
  10. De'Longhi EC155 Water Valve Replacement: шаг 10, изображение 1 из 2 De'Longhi EC155 Water Valve Replacement: шаг 10, изображение 2 из 2
    • Pull the tube through the chamber with the water pump so it comes out of the top end.
    • Twist the valve counterclockwise while pulling gently.
Заключение
5 участников успешно повторили данное руководство.
David Griffith
Участник с: 10/01/15
1 471 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 4-2, Maness Fall 2015 Участник Cal Poly, Team 4-2, Maness Fall 2015
CPSU-MANESS-F15S4G2
4 членов
Автор 25 руководств
4 Комментариев
I done this earlier today without the guide after it started to leak after descaling the machine , so i fixed it by taking valve apart an putting back together it worked once before leaking again , im just concerned it will just go again if i replace the safety valve , im wondering if scale has moved an is blocking and causing valve to leak? any ideas?
Russell L - Ответить
Great description! Is the water valve ever used to control brew pressure?
Thatcher Drake - Ответить
Great guide!, carefull the water valve has inside, two small orings, don´t loss it. Muy buena guia, hice todo lo indicado y funciono perfectamente, mi máquina comenzo a gotear agua por dentro y gracias a este manual pude encontrar la falla, que es la válvula, tengo con la maquina mas de 7 años y hasta ahora fallo, la válvula por ser de plastico no se puede reparar, pero se consiguen las partes en ereplacementparts.com. Solo un comentario la valvula tiene 2 orings pequeños, así que tengan cuidado cuando la saquen no se les pierdan.
Nelson Troyano - Ответить
I update my comment, the spare part for the valve has arrived (ereplacementparts.com), I replaced it and everything is perfect, I can drink my espresso again.
Actualizo mi comentario, ya me llego el repuesto de la válvula (ereplacementparts.com), lo reemplace y todo perfecto, de nuevo puedo tomar mi expresso.
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 10
За последние 30 дней: 53
За всё время: 5,544
