DeLonghi ESAM xxxx - Test Mode
  1. DeLonghi ESAM  xxxx - Test Mode, Activate Test Mode: шаг 1, изображение 1 из 2 DeLonghi ESAM  xxxx - Test Mode, Activate Test Mode: шаг 1, изображение 2 из 2
    • Pull the plug. Switch on rear side is in position "On".
    • Press and hold both keys for "one cup" and "steam".
    • Reconnect the plug.
    • LEDs light up. When they are off again, the machine is in test mode. Release the two keys.
    • If there is no water in the reservoir or not all drawers are inserted correctly, corresponding LEDs will light up.
  2. DeLonghi ESAM  xxxx - Test Mode, Motor Test: шаг 2, изображение 1 из 2 DeLonghi ESAM  xxxx - Test Mode, Motor Test: шаг 2, изображение 2 из 2
    • Press the key "one cup". The motor should drive down. If it reaches the lower end position the correspondending LED will light up.
    • Press the key two cups". The motor should drive upwards. If it reaches the upper end position the correspondending LED will light up.
    • Tip: the brewing unit has to be in the right start position for correct function. It's a good idea to take a foto or mark the position.
    • If the lower four LEDs light up in sequence during later operation, the start position has not yet been set correctly. Take out the brewing unit and close the service door. Press the "one cup" and "two cups" buttons simultaneously, the motor will automatically search for the right position. Put the brewing unit back in.
  3. DeLonghi ESAM  xxxx - Test Mode, Pump Test: шаг 3, изображение 1 из 1
    • Press the "steam" key. The pump should be activated. If the steam wand is opened the water should flow.
  4. DeLonghi ESAM  xxxx - Test Mode, Grinder Test: шаг 4, изображение 1 из 1
    • Press the "ECO" key. The grinder should be activated.
  5. DeLonghi ESAM  xxxx - Test Mode, Heater Test: шаг 5, изображение 1 из 1
    • Press the "Rinse" key. One LED should light up and the heater should be activated. If it reaches the end temperature, the LED goes out.
  6. DeLonghi ESAM  xxxx - Test Mode: шаг 6, изображение 1 из 1
    • Pull the plug again to leave the test mode.
Заключение
Еще один человек закончил это руководство.
Особая благодарность этим переводчикам:
de en
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
VauWeh
Участник с: 10/19/15
297 490 Репутация
Автор 303 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 15
За последние 7 дней: 93
За последние 30 дней: 362
За всё время: 18,579
