Введение
This guide will walk you through replacing the plastic arms holding the brushes in place. These are both located at the base of the brush motor and are required for electrical connection.
Выберете то, что вам нужно
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
Using the T-6 screwdriver, unscrew torx screw holding the arm in place.
Еще один человек закончил это руководство.
