Введение
In this guide you will take apart the pinion "head" of the grinder to gain access to components in the gear case.
Выберете то, что вам нужно
Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
Remove the armature assembly from the gear case.
Remove the pinion from the armature assembly.
2 участников успешно повторили данное руководство.
