Введение
This guide details removal and replacement of the motor armature assembly.
Выберете то, что вам нужно
Remove the shoe by pressing the yellow button on the left side of the hand grip.
Remove the M3x16mm T10 screw from the back of the grip. Keep it separate from the rest of the grip screws
Remove the six M3.63x19 T15 screws from the grip.
Remove the top half of the grip.
Turn the saw over and locate the power connectors to the motor.
Use needle nose pliers to remove the spade connectors. Take care not to grab the wires on removal, only the end of the spade terminal.
Remove three M8x18 T20 bolts from the back of the gearbox.
Pull the motor case off of the armature.
Remove two M8x12mm T20 bolts from the bearing retainer.
Pull the shaft out of the gearbox.
