Введение
This guide details replacement of the upper motor armature containing the brushes and main power connectors.
Выберете то, что вам нужно
Remove the shoe by pressing the yellow button on the left side of the hand grip.
Remove the M3x16mm T10 screw from the back of the grip. Keep it separate from the rest of the grip screws
Remove the six M3.63x19 T15 screws from the grip.
Remove the top half of the grip.
Turn the saw over and locate the power connectors to the motor.
Use needle nose pliers to remove the spade connectors. Take care not to grab the wires on removal, only the end of the spade terminal.
Remove four M8x32mm T20 bolts from the base of the gearbox.
Pull the gearbox and motor out of the center housing.
Remove three M8x18mm T20 bolts from the back of the gearbox.
Pull the motor armature out of the casing.
Remove two M3.63x60mm T10 bolts from the inner edge of the motor case.
Pull the brush housing off the top, leaving the bottom half in place.
Use tweezers to unload the springs from the new set of brushes.
Pull the brush heads back as far as the casing will allow.
Reload the springs after the armature has be re-seated.
