Введение
The power cord can simply be replaced by opening the back of the device and unscrewing the casing. Make sure that the device is not plugged in before working on it.
Выберете то, что вам нужно
Using a T20 Torx Screwdriver, unscrew the four 19mm screws from the back casing.
After unscrewing, remove the back casing from the device.
Using the T20 Torx screwdriver, unscrew two screws from the bracket that holds the power cord in the casting.
Еще один человек закончил это руководство.
