Введение
The DeWalt DW920 Motor Replacement is a simple and effective way to replace your damaged motor in the DeWalt DW920, which is a power tool used as a drill. This repair may be needed after years of a motor being used, and may be worn out or damaged. Replacing the motor will not only make it feel like a brand new device, it will give you years of use with a new motor. Special skills are not required for this and instructions to build are in the steps section.
Выберете то, что вам нужно
Use a Phillips #2 screwdriver to remove the four screws to open up the case.
Remove the outer housing to reveal the screws that are used to connect the outer covering of the drill.
Use a Phillips #2 screwdriver to remove all the screws that join the two parts of the casing.
Take the two halves of the housing and carefully pry them apart.
Find and replace the old trigger. The trigger assembly should be found inside the drill.
The trigger is the component affixed to the motor and the wires. Loosen the wiring of the trigger carefully so that you can separate the connections of the terminals.
Install the new trigger. Place the new trigger in the position within the housing where the old trigger originated from.
Solder the wires together by placing the terminal in the connector.
Make sure the trigger is locked tightly in its position.
To reassemble the drill align the two halves of the housing back in their original positions, making sure that the internal parts, and in particular the trigger, are correctly positioned.
Put the screws back into their respective holes and fasten them with the Phillips #2 screwdriver.
Test the trigger either by connecting the battery again or plugging the drill back in.
Pull the trigger to make the drill glide and to engage the rig. If it will not operate correctly, retract and examine its wiring and the position of the trigger.
Gently lift the motor and trigger mechanism out from the frame of the drill.
Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
Mark where the two cables was connected using a masking tape or similar.
Solder the new motor assembly wires to the trigger mechanism in the same fashion that the old motor was.
Remember to check the markers from the step before and solder the cables on the right place.
- Follow the case replacement guide for how to replace the case on the drill.
- The trigger replacement guide is located above.
- To reassemble the device, follow the instructions in reverse.
