DeWalt DW920 Trigger Replacement
Выберете то, что вам нужно
  1. DeWalt DW920 Trigger Replacement, Trigger: шаг 1, изображение 1 из 1
    • Use a Phillips #2 screwdriver to remove the four screws to open up the case.
    • Ensure that the drill is unplugged and remove the battery to avoid electrical shock or accidental activation.
  2. DeWalt DW920 Trigger Replacement: шаг 2, изображение 1 из 1
    • Remove the outer housing to reveal the screws that are used to connect the outer covering of the drill.
    • Use a Phillips #2 screwdriver to remove all the screws that join the two parts of the casing.
    • Take the two halves of the housing and carefully pry them apart.
    • Make sure not to touch any parts in the interior of the screwdriver.
  3. DeWalt DW920 Trigger Replacement: шаг 3, изображение 1 из 1
    • Find and replace the old trigger. The trigger assembly should be found inside the drill.
    • The trigger is the component affixed to the motor and the wires. Loosen the wiring of the trigger carefully so that you can separate the connections of the terminals.
    • Remove the wires. Then take a picture so that you can remember how they should be connected. Pull the old trigger out from its engagement with the housing.
  4. DeWalt DW920 Trigger Replacement: шаг 4, изображение 1 из 1
    • Install the new trigger. Place the new trigger in the position within the housing where the old trigger originated from.
    • Solder the wires together by placing the terminal in the connector.
    • Check the wire connections with the help of the photo which was taken earlier, if it is necessary.
    • Make sure the trigger is locked tightly in its position.
  5. DeWalt DW920 Trigger Replacement: шаг 5, изображение 1 из 1
    • To reassemble the drill align the two halves of the housing back in their original positions, making sure that the internal parts, and in particular the trigger, are correctly positioned.
    • Put the screws back into their respective holes and fasten them with the Phillips #2 screwdriver.
    • Screw the nuts at an angle to make sure it will tightening uniformly.
  6. DeWalt DW920 Trigger Replacement: шаг 6, изображение 1 из 1
    • Test the trigger either by connecting the battery again or plugging the drill back in.
    • Pull the trigger to make the drill glide and to engage the rig. If it will not operate correctly, retract and examine its wiring and the position of the trigger.
    • If you meet any problems or have troubles with the trigger, don’t force it. Go back to the previous steps.
Заключение
Stephen Rada
Участник с: 03/11/16
433 Репутация
Автор 4 руководств
Команду
UMass Dartmouth, Team 8-2, Botvin Spring 2016 Участник UMass Dartmouth, Team 8-2, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G2
2 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 12
За последние 30 дней: 21
За всё время: 704
