Введение
This guide will show you how to replace the black air filter cap located on the top of the motor.
Запчасти
No parts specified.
  1. Using a T-20 hex head screw, unscrew the two screws located at the top and bottom of the black air filter. The screws are directly above and below the yellow  lettering.
    • Using a T-20 hex head screw, unscrew the two screws located at the top and bottom of the black air filter. The screws are directly above and below the yellow lettering.
  2. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  3. Use your hands to pull the black air filter away from the body of the saw to detach.
    • Use your hands to pull the black air filter away from the body of the saw to detach.
Заключение
Scott Weinhardt
Участник с: 25.01.2017
522 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 8-2, Banghart Winter 2017 Member of Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 165
