Введение
If the drill is on but not spinning, then the motor should be replaced.
Выберете то, что вам нужно
Remove seven 21 mm Torx T15 screws.
Remove one 18 mm Torx T10 screw.
After removing all screws, lift up the top yellow cover.
Lift the components out of the casing. These include: motor, gear assembly, trigger assembly and chuck.
Еще один человек закончил это руководство.
