Введение
This guide will show you how to disassemble your drill in order to replace the speed switch.
Выберете то, что вам нужно
Remove seven 21 mm Torx T15 screws.
Remove one 18 mm Torx T10 screw.
After removing all screws, lift up the top yellow cover.
Lift the components out of the casing. These include: motor, gear assembly, trigger assembly and chuck.
Почти готово!
Заключение
