Введение
Is your DeWalt reciprocating saw stopping and starting sporadically or catching while in use? You may be experiencing an issue with the gear assembly, below are the steps to help you replace the gear assembly and return your device to working condition.
Выберете то, что вам нужно
Remove the seven 3/4" Button Head Torx Security screws out of the handle with the Torx T20H bit and IFixit Precision Bit Driver.
Take the top cover off after the screws have been removed to access the trigger assembly.
Remove the single 3/4" Button Head Torx Security screw that is securing the trigger assembly using the Torx T15H bit.
Pull the entire trigger assembly from the handle.
Use the pointed end of the metal sludger to pry open the rectangular casing that houses the electrical contacts and wiring of the trigger assembly.
Assess the condition of the assembly by checking the inside of the casing for any dust, dirt, or misalignment.
Look on the back of the assembly by turning it over to the casing where the wires protrude and see if there is any damage to the cables which are connected to the motor assembly.
If any part of the trigger assembly such as electrical contacts, wiring, or the spring is damaged beyond repair, then replace the assembly and reconnect the new component to the wiring attached from the motor assembly.
Use a #2 Phillips Screwdriver to remove the large black screw at the shoe of the device or the black plastic housing.
Use a Torx T20H bit and the iFixit Precision Bit Driver to remove the four 3/4" Button Head Torx Security screws from inside the shoe housing.
Once the four safety housing bolts are removed, pull the black plastic cover (the shoe) from the device.
Slide the black rubber component (the boot) off to access the reciprocating shaft assembly and metal plate.
Remove the four 1.5” Stainless Steel Button Head Torx screws that are attached to the gold metal plate. Remove the screws using a Torx T25H bit with the iFixit Precision Bit Driver.
Remove the two smaller black ¾” Button Head Torx Screws using the Torx T20H bit with the iFixit Precision Bit Driver.
Remove the gold metal plate carefully. You may need to use a flat tool to pry the cover off from the sticky surface.
After removing the plate, the reciprocating shaft is now exposed. Remove the shaft and assess it for damages or loss of lubrication.
If the shaft is not lubricated, apply saw lubricant generously.
Assess the front of the shaft where the blade goes. If dust or dirt are clogging the shaft, carefully clean the shaft with small cotton swabs and cleaning fluid.
If any part on the reciprocating shaft is damaged, then replace the reciprocating shaft with a new part.
Remove the heavy, grey metal cover that is located above the gear to access the assembly. Put aside the metal cover and carefully lift gear assembly out.
Evaluate the gear to ensure that no dirt or debris is jamming the gear assembly. Be sure to also evaluate the teeth of the gear, making sure no teeth have broken. Clean the gear assembly and replace gear as required.
