Введение
This guide outlines how to replace the motherboard of the Definitive Technology W7, with a model number of 093207098505.
Выберете то, что вам нужно
Flip the speaker upside down, then use the Phillips #2 screwdriver remove the 4 screws securing the bottom cover.
Use the metal spudger to remove all rubber feet.
Unscrew all four screws from under the rubber feet.
You can now use the prying tool to pry the bottom panel off the speaker.
Push up the locking tabs on the sides of the ribbon cable connector.
Gently pull the ribbon cable out from the connector to remove it.
Tilt the motherboard outwards from the speaker.
Remove all five connectors from the motherboard.
Remove the motherboard from the speaker.
Using the Phillips #2 screwdriver, remove the three screws from the network card.
Remove the network card from the motherboard.
