Введение
Following this guide involves completely disassembling the monitor. This process isn't terribly difficult, just time consuming.
Выберете то, что вам нужно
Carefully place the monitor face down on a flat surface, being careful to protect the display.
Remove the four 10 mm Phillips #2 screws from the back panel.
Flip the monitor back over, so that the display is facing you.
Use a spudger to remove the front bezel by unsnapping it in a counter clockwise fashion, starting at the bottom right, and ending at the button panel.
Carefully flip the monitor back over, making sure to keep the front bezel in place.
Lift the back cover off of the rest of the monitor.
Locate the USB port cover on the right hand side of the monitor.
Remove the one 5 mm Phillips #2 screw.
Remove the USB port cover by sliding it out and away from the monitor.
Remove the four 4 mm Phillips #2 screws that secure the monitor mount release mechanism to the panel.
Set this mechanism off to the side, taking care to keep it all in one piece.
Use a 5 mm nut driver to remove the four 12 mm standoff screws securing the video connectors to the panel.
Use the tweezers to lift up the seven security tabs that secure the back panel to the rest of the monitor.
Open up the clip securing the wires running between the power supply and video boards.
Gently remove the connector running from the video board to the power supply board.
8 участников успешно повторили данное руководство.
