Dell Adamo XPS Bridge Battery Replacement
Выберете то, что вам нужно
    • Turn off the laptop before doing anything to the laptop.
    • Then turn the laptop around on its back.
    • On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
    • Then you have to push the computer battery towards the computer and rotate upwards.
    • Finally lift the battery out of the computer.
    • Turn the computer around and remove the eighteen screws on the base cover.
    • The screws that secure the base cover are of different sizes. Note the location and size of the screws as you remove them so that you can replace them correctly
    • You aren't actually taking apart the display but only opening it up to gain access to the palm rest panel and keyboard.
    • Use your fingers to ease the palm rest assembly from the computer.
    • Pull on the plastic tab on top of the cables to avoid damaging the connectors.
    • Exercise extreme care while lifting the palm rest assembly to avoid damaging the function key cable.
    • Lift the palm rest assembly to access the function key cable.
    • To prevent damage to the function key cable, do not disconnect the function key cable from the palm rest.
    • Disconnect the function key cable from the connector on the system board.
    • Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
    • To prevent damage to the display hinges, ensure that you do not adjust the angle between the display and the computer base after removing the palm rest assembly.
    • Lift the palm rest assembly off the computer base.
    • After removing the laptop battery and the pal rest panel.
    • Disconnect the bridge battery cable from the connector on the left daughter board.
    • Be careful prying out the bridge battery.
    • The bridge battery is glued to the base cover. Use the spudger to pry the bridge battery out of the base cover.
    • Use adhesive on the bridge battery to ahere it to the base cover.
    • Reconnect the bridge battery cable to the connector on the left daughter board.
Заключение
Christopher Melo-Pelaez
Участник с: 10/27/17
1 921 Репутация
Автор 9 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
44 членов
Автор 1 997 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 25
За всё время: 520
