Введение
We will be removing the Palm Rest panel from the computer which will allow us to access the internals of the computer.
Выберете то, что вам нужно
Шаг 1 Removal of the Laptop Battery
Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
Then turn the laptop around on its back.
On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
Then you have to push the computer battery towards the computer and rotate upwards.
Finally lift the battery out of the computer.
Turn the computer around and remove the eighteen screws on the base cover.
Use your fingers to ease the palm rest assembly from the computer.
Lift the palm rest assembly to access the function key cable.
Disconnect the function key cable from the connector on the system board.
Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
Еще один человек закончил это руководство.
