Введение
We will remove the Solid State Drive from the computer and replace it. We will have to do all the precursors before removing the Solid State Drive.
Выберете то, что вам нужно
On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
Then you have to push the computer battery towards the computer and rotate upwards.
Finally lift the battery out of the computer.
Turn the computer around and remove the eighteen screws on the base cover.
Use your fingers to ease the palm rest assembly from the computer.
Lift the palm rest assembly to access the function key cable.
Disconnect the function key cable from the connector on the system board.
Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
Remove the screw that secures the solid state drive to the computer base.
Slide and lift the solid state drive to disconnect it from the connector on the right daughter board.
Get the new drive from the packaging .
Push the solid state drive until it is fully connected to the connector on the right daughter board.
Replace the screw that secures the solid state drive to the computer base.
Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so result in damage to the computer.
Install the operating system for your computer, as needed.
Install the drivers and utilities for your computer, as needed.
