Dell Alienware 13 Coin-Cell Battery Replacement
Выберете то, что вам нужно
  1. Dell Alienware 13 Coin-Cell Battery Replacement, Base Panel: шаг 1, изображение 1 из 1
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Coin-Cell Battery Replacement: шаг 2, изображение 1 из 1
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Coin-Cell Battery Replacement: шаг 3, изображение 1 из 3 Dell Alienware 13 Coin-Cell Battery Replacement: шаг 3, изображение 2 из 3 Dell Alienware 13 Coin-Cell Battery Replacement: шаг 3, изображение 3 из 3
    • Remove the small access panel using a heavy duty spudger.
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  4. Dell Alienware 13 Coin-Cell Battery Replacement, Pull Tab: шаг 5, изображение 1 из 1
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  5. Dell Alienware 13 Coin-Cell Battery Replacement, Disconnecting the State Drive: шаг 6, изображение 1 из 1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  6. Dell Alienware 13 Coin-Cell Battery Replacement, Remove Screws: шаг 7, изображение 1 из 1
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  7. Dell Alienware 13 Coin-Cell Battery Replacement, Solid-State Drive Assembly Lift: шаг 8, изображение 1 из 2 Dell Alienware 13 Coin-Cell Battery Replacement, Solid-State Drive Assembly Lift: шаг 8, изображение 2 из 2
    • Lift the solid-state drive assembly off the computer base.
    • Make sure the screws are off the solid-state assembly.
  8. Dell Alienware 13 Coin-Cell Battery Replacement, Slide and Lift: шаг 9, изображение 1 из 1
    • Slide and lift the solid-state drive off the solid-state assembly.
  9. Dell Alienware 13 Coin-Cell Battery Replacement, Replacing the Solid-State Drive: шаг 10, изображение 1 из 1
    • Slide the new solid-state drive into the solid-state drive assembly.
  10. Dell Alienware 13 Coin-Cell Battery Replacement, Replace the Screw: шаг 11, изображение 1 из 1
    • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
  11. Dell Alienware 13 Coin-Cell Battery Replacement, Screw Align: шаг 12, изображение 1 из 1
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  12. Dell Alienware 13 Coin-Cell Battery Replacement, Screw Replacement: шаг 13, изображение 1 из 1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  13. Dell Alienware 13 Coin-Cell Battery Replacement, Connecting the Drive: шаг 14, изображение 1 из 1
    • Connect the solid-state drive cable to the system board.
  14. Dell Alienware 13 Coin-Cell Battery Replacement, Aligning Screws: шаг 15, изображение 1 из 1
    • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  15. Dell Alienware 13 Coin-Cell Battery Replacement, Replacing Screws: шаг 16, изображение 1 из 1
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  16. Dell Alienware 13 Coin-Cell Battery Replacement, Disconnecting the Keyboard: шаг 17, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
  17. Dell Alienware 13 Coin-Cell Battery Replacement, Removing the Screws: шаг 18, изображение 1 из 2 Dell Alienware 13 Coin-Cell Battery Replacement, Removing the Screws: шаг 18, изображение 2 из 2
    • Remove the screws that secure the palm-rest assembly to the computer base.
  18. Dell Alienware 13 Coin-Cell Battery Replacement, Popping out the Palm-Rest Assembly: шаг 19, изображение 1 из 1
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
  19. Dell Alienware 13 Coin-Cell Battery Replacement, Turn the Computer Over: шаг 20, изображение 1 из 1
    • Turn the computer over and open the display as far as possible.
  20. Dell Alienware 13 Coin-Cell Battery Replacement, Prying the Edges: шаг 21, изображение 1 из 1
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  21. Dell Alienware 13 Coin-Cell Battery Replacement, Lifting the Palm-Rest Assembly: шаг 22, изображение 1 из 1
    • Gently lift the palm-rest assembly and turn it over.
  22. Dell Alienware 13 Coin-Cell Battery Replacement, Disconnecting the Power-Board Cable: шаг 23, изображение 1 из 2 Dell Alienware 13 Coin-Cell Battery Replacement, Disconnecting the Power-Board Cable: шаг 23, изображение 2 из 2
    • Lift the connector latch and disconnect the power-button board cable from the system board.
    • Remove the Keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
  23. Dell Alienware 13 Coin-Cell Battery Replacement, Connecting the Power-Button Board Cable: шаг 26, изображение 1 из 1
    • Connect the power-button board cable to the system board.
  24. Dell Alienware 13 Coin-Cell Battery Replacement, Aligning the Palm-Rest Assembly.: шаг 27, изображение 1 из 1
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Close the display and turn the computer over.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
  25. Dell Alienware 13 Coin-Cell Battery Replacement, Disconnecting the Touchpad Cable: шаг 31, изображение 1 из 3 Dell Alienware 13 Coin-Cell Battery Replacement, Disconnecting the Touchpad Cable: шаг 31, изображение 2 из 3 Dell Alienware 13 Coin-Cell Battery Replacement, Disconnecting the Touchpad Cable: шаг 31, изображение 3 из 3
    • Lift the connector latches and disconnect the touchpad cable and the status-light cable from the power-button board.
  26. Dell Alienware 13 Coin-Cell Battery Replacement, Peeling the Cables: шаг 32, изображение 1 из 1
    • Peel the touchpad cable and status-light cable off the keyboard bracket.
  27. Dell Alienware 13 Coin-Cell Battery Replacement, Removing the Keyboard Bracket: шаг 33, изображение 1 из 1
    • Lift the keyboard bracket off the palm-rest assembly.
  28. Dell Alienware 13 Coin-Cell Battery Replacement, Remove the Screws: шаг 34, изображение 1 из 1
    • Remove the screws that secure the keyboard to the palm-rest assembly.
  29. Dell Alienware 13 Coin-Cell Battery Replacement, Lifting the Keyboard: шаг 35, изображение 1 из 1
    • Slide and lift the keyboard, along with the cables, off the palm-rest assembly.
  30. Dell Alienware 13 Coin-Cell Battery Replacement, Aligning the Screw Holes: шаг 36, изображение 1 из 1
    • Align the screw holes on the NEW keyboard with the screw holes on the palm-rest assembly.
  31. Dell Alienware 13 Coin-Cell Battery Replacement, Replacing Screws: шаг 37, изображение 1 из 1
    • Replace the screws that secure the keyboard to the palm-rest assembly.
    • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
  32. Dell Alienware 13 Coin-Cell Battery Replacement, Replace the Screws: шаг 39, изображение 1 из 1
    • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
  33. Dell Alienware 13 Coin-Cell Battery Replacement, Adhering the Cables: шаг 40, изображение 1 из 2 Dell Alienware 13 Coin-Cell Battery Replacement, Adhering the Cables: шаг 40, изображение 2 из 2
    • Adhere the touchpad cable and status-light cable to the keyboard bracket.
  34. Dell Alienware 13 Coin-Cell Battery Replacement, Sliding the Cables: шаг 41, изображение 1 из 1
    • Slide the touchpad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
  35. Dell Alienware 13 Coin-Cell Battery Replacement, Remove the Screw: шаг 42, изображение 1 из 2 Dell Alienware 13 Coin-Cell Battery Replacement, Remove the Screw: шаг 42, изображение 2 из 2
    • Remove the screw that secures the power-adapter port bracket to the power-adapter port.
  36. Dell Alienware 13 Coin-Cell Battery Replacement, Lift the Power-Adapter: шаг 43, изображение 1 из 1
    • Lift the power-adapter port bracket off the power-adapter port.
    • Release the power-adapter port from the computer base.
  37. Dell Alienware 13 Coin-Cell Battery Replacement, Disconnect the Speaker Cable: шаг 45, изображение 1 из 1
    • Disconnect the speaker cable from the system board.
  38. Dell Alienware 13 Coin-Cell Battery Replacement, Remove the Screws: шаг 46, изображение 1 из 1
    • Remove the screws that secure the system board to the computer base.
  39. Dell Alienware 13 Coin-Cell Battery Replacement, Slide and Lift the System-Board Assembly: шаг 47, изображение 1 из 1
    • Slide and lift the system-board assembly.
    • Turn the system-board assembly over.
  40. Dell Alienware 13 Coin-Cell Battery Replacement, Disconnect the Power-Adapter Port Cable: шаг 49, изображение 1 из 1
    • Disconnect the power-adapter port cable and remove the power-adapter port from the system board.
  41. Dell Alienware 13 Coin-Cell Battery Replacement, Connect the Power-Adapter Port Cable: шаг 50, изображение 1 из 1
    • Connect the power-adapter port cable to the system board.
    • Turn the system board over.
  42. Dell Alienware 13 Coin-Cell Battery Replacement, Replace the Screws: шаг 52, изображение 1 из 1
    • Replace the screws that secure the system board to the computer base.
  43. Dell Alienware 13 Coin-Cell Battery Replacement, Connect the Speaker Cable: шаг 53, изображение 1 из 1
    • Connect the speaker cable to the connector on the system board.
  44. Dell Alienware 13 Coin-Cell Battery Replacement, Align the Power-Adapter Port: шаг 54, изображение 1 из 1
    • Align the power-adapter port to the computer base.
    • Align the screw hole on the power-adapter port bracket with the screw hole on the power-adapter port.
    • Replace the screw that secures the power-adapter port bracket to the power-adapter port.
  45. Dell Alienware 13 Coin-Cell Battery Replacement, Disconnecting the Coin-Cell Battery Cable: шаг 57, изображение 1 из 2 Dell Alienware 13 Coin-Cell Battery Replacement, Disconnecting the Coin-Cell Battery Cable: шаг 57, изображение 2 из 2
    • Disconnect the coin-cell battery cable from the connector on the system board.
    • Peel the coin-cell battery off the system board.
  46. Dell Alienware 13 Coin-Cell Battery Replacement, Adhering the Coin-Cell Battery: шаг 59, изображение 1 из 1
    • Adhere the NEW coin-cell battery to the system board.
  47. Dell Alienware 13 Coin-Cell Battery Replacement, Connect the Coin-Cell Battery: шаг 60, изображение 1 из 1
    • Connect the coin-cell battery cable to the connector on the system board.
Заключение
Terrence15
Участник с: 12/18/17
79 161 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 986 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 285
