Введение
In this guide, we will be revealing on how to remove and replace the Palm Rest Replacement on the Dell Alienware 13.
Выберете то, что вам нужно
Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
Remove the screws that secure the palm-rest assembly to the computer base.
Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
Turn the computer over and open the display as far as possible.
Using a plastic scribe, pry up along the edges of the palm-rest assembly.
Gently lift the palm-rest assembly and turn it over.
Lift the connector latch and disconnect the power-button board cable from the system board.
Remove the Keyboard.
Remove the power-button board.
Remove the status-light board.
Remove the touchpad.
Replace the touchpad.
Replace the status-light board.
Replace the power-button board.
Replace the keyboard.
Connect the power-button board cable to the system board.
Align the palm-rest assembly on the computer base and snap it into place.
Close the display and turn the computer over.
Replace the screws that secure the palm-rest assembly to the computer base.
Connect the keyboard cable and the keyboard-backlight cable to the system board.
