Dell Alienware 13 R2 Camera Replacement
Выберете то, что вам нужно
  1. Dell Alienware 13 R2 Camera Replacement, Turning Over the PC: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer After working inside your computer, follow the instructions in After Working Inside Your Computer For more safety best practices, see the regulatory compliance home page.
    • Close the display and turn the computer over.
  2. Dell Alienware 13 R2 Camera Replacement, Loosen the screws: шаг 2, изображение 1 из 1
    • Loosen the captive screws that secure the base panel to the computer base.
  3. Dell Alienware 13 R2 Camera Replacement, Releasing the Tabs: шаг 3, изображение 1 из 1
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  4. Dell Alienware 13 R2 Camera Replacement, Disconnecting the Battery Cable: шаг 4, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Disconnecting the Battery Cable: шаг 4, изображение 2 из 2
    • Disconnect the battery cable from the battery-cable connector.
    • Turn the computer over.
  5. Dell Alienware 13 R2 Camera Replacement, Power Button: шаг 5, изображение 1 из 1
    • Press and hold the power button for 5 seconds to ground the system board.
    • Connect the battery cable to the battery-cable connector.
  6. Dell Alienware 13 R2 Camera Replacement, Aligning the tabs: шаг 7, изображение 1 из 1
    • Align the tabs on the base panel with the slots on the computer base and snap the base panel into place.
  7. Dell Alienware 13 R2 Camera Replacement, Tighten the screws: шаг 8, изображение 1 из 1
    • Tighten the captive screws that secure the base panel to the computer base.
  8. Dell Alienware 13 R2 Camera Replacement, Removing the Screws: шаг 9, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Removing the Screws: шаг 9, изображение 2 из 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  9. Dell Alienware 13 R2 Camera Replacement, Peel off Computer Base Tabs: шаг 10, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Peel off Computer Base Tabs: шаг 10, изображение 2 из 2
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  10. Dell Alienware 13 R2 Camera Replacement, Disconnecting the Solid-State Drive Cable: шаг 11, изображение 1 из 1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  11. Dell Alienware 13 R2 Camera Replacement, Removing the Solid-State Drive: шаг 12, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Removing the Solid-State Drive: шаг 12, изображение 2 из 2
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  12. Dell Alienware 13 R2 Camera Replacement, Lifting the Solid-State Assembly: шаг 13, изображение 1 из 1
    • Lift the solid-state drive assembly off the computer base.
  13. Dell Alienware 13 R2 Camera Replacement, Remove the Screw: шаг 14, изображение 1 из 1
    • Remove the screw that secures the solid-state drive to the solid-state drive assembly.
  14. Dell Alienware 13 R2 Camera Replacement, Lift the Solid-State Assembly.: шаг 15, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Lift the Solid-State Assembly.: шаг 15, изображение 2 из 2
    • Slide and lift the solid-state drive off the solid-state drive assembly.
  15. Dell Alienware 13 R2 Camera Replacement, The New Solid-State Drive: шаг 16, изображение 1 из 1
    • Slide the NEW solid-state drive into the slot on the solid-state drive assembly.
  16. Dell Alienware 13 R2 Camera Replacement, Screw Replacement: шаг 17, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Screw Replacement: шаг 17, изображение 2 из 2
    • Replace the screw that secures the solid-state drive to the solid-state drive assembly.
  17. Dell Alienware 13 R2 Camera Replacement, Align the Screws: шаг 18, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Align the Screws: шаг 18, изображение 2 из 2
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  18. Dell Alienware 13 R2 Camera Replacement, Replace the Screws: шаг 19, изображение 1 из 1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  19. Dell Alienware 13 R2 Camera Replacement, Connect the Cable to the System Board: шаг 20, изображение 1 из 1
    • Connect the solid-state drive cable to the system board.
  20. Dell Alienware 13 R2 Camera Replacement, Align the Screw Holes: шаг 21, изображение 1 из 1
    • Align the screw holes on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  21. Dell Alienware 13 R2 Camera Replacement, Replace the Screws: шаг 22, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Replace the Screws: шаг 22, изображение 2 из 2
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  22. Dell Alienware 13 R2 Camera Replacement, Lifting the Latches: шаг 23, изображение 1 из 1
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board.
  23. Dell Alienware 13 R2 Camera Replacement, Remove the Screws: шаг 24, изображение 1 из 1
    • Remove the screws that secure the palm-rest assembly to the computer base.
  24. Dell Alienware 13 R2 Camera Replacement, Lift the Computer Base: шаг 25, изображение 1 из 1
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
    • Turn the computer over and open the display as far as possible.
  25. Dell Alienware 13 R2 Camera Replacement, Prying the Palm-Rest Assembly: шаг 27, изображение 1 из 1
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  26. Dell Alienware 13 R2 Camera Replacement, Lift the Palm-Rest Assembly: шаг 28, изображение 1 из 1
    • Gently lift the palm-rest assembly and turn it over.
  27. Dell Alienware 13 R2 Camera Replacement, Lift the Connector Latch: шаг 29, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Lift the Connector Latch: шаг 29, изображение 2 из 2
    • Lift the connector latch and disconnect the power-button board cable from the system board.
  28. Dell Alienware 13 R2 Camera Replacement, Lift the Palm-Rest Assembly: шаг 30, изображение 1 из 1
    • Lift the palm-rest assembly off the computer base.
  29. Dell Alienware 13 R2 Camera Replacement, Removing: шаг 31, изображение 1 из 1
    • Remove the keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the Touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
    • Connect the power-button board cable to the system board.
  30. Dell Alienware 13 R2 Camera Replacement, Align the Palm-Rest Assembly: шаг 34, изображение 1 из 1
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
  31. Dell Alienware 13 R2 Camera Replacement, Remove the Screws: шаг 39, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Remove the Screws: шаг 39, изображение 2 из 2
    • Remove the screws that secure the hinge caps to the display hinges.
  32. Dell Alienware 13 R2 Camera Replacement, Lifting the Hinge Caps: шаг 40, изображение 1 из 1
    • Slide and lift the hinge caps off the display hinges.
  33. Dell Alienware 13 R2 Camera Replacement, Remove the Screw: шаг 42, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Remove the Screw: шаг 42, изображение 2 из 2
    • Remove the screw that secures the wireless-card bracket to the wireless card.
  34. Dell Alienware 13 R2 Camera Replacement, Disconnect the Antenna Cables: шаг 43, изображение 1 из 1
    • Disconnect the antenna cables from the wireless card.
    • Turn the computer over and open the display.
  35. Dell Alienware 13 R2 Camera Replacement, Remove the Antenna Cables: шаг 45, изображение 1 из 1
    • Remove the antenna cables from the routing guides on the display hinges.
  36. Dell Alienware 13 R2 Camera Replacement, Disconnect the Display Cable: шаг 46, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Disconnect the Display Cable: шаг 46, изображение 2 из 2
    • Lift the connector latch and disconnect the display cable from the system board.
  37. Dell Alienware 13 R2 Camera Replacement, Remove the Display Cable: шаг 47, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Remove the Display Cable: шаг 47, изображение 2 из 2
    • Remove the display cable from the routing guides on the display hinges.
  38. Dell Alienware 13 R2 Camera Replacement, Disconnect the Logo-Board Cable: шаг 48, изображение 1 из 1
    • Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
  39. Dell Alienware 13 R2 Camera Replacement, Remove the Screws: шаг 49, изображение 1 из 1
    • Remove the screws that secure the display assembly to the computer base.
    • Lift the display assembly off the computer base.
  40. Dell Alienware 13 R2 Camera Replacement, Align the Screw Holes: шаг 51, изображение 1 из 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  41. Dell Alienware 13 R2 Camera Replacement, Replace the Screws: шаг 52, изображение 1 из 1
    • Replace the screws that secure the display hinges to the computer base.
  42. Dell Alienware 13 R2 Camera Replacement, Routing the Logo-Board Cable: шаг 53, изображение 1 из 1
    • Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
  43. Dell Alienware 13 R2 Camera Replacement, Route the Cable: шаг 54, изображение 1 из 1
    • Route the display cable through the routing guides on the display hinge.
  44. Dell Alienware 13 R2 Camera Replacement, Slide the Display Cable: шаг 55, изображение 1 из 1
    • Slide the display cable into the connector on the system board and press down the latch to secure the cable.
    • Route the antenna cables through the routing guides on the display hinges.
  45. Dell Alienware 13 R2 Camera Replacement, Adhere the Adhesive Tapes: шаг 57, изображение 1 из 1
    • Adhere the adhesive tapes that secure the antenna cables to the system board.
    • Connect the antenna cables to the wireless card.
    • Replace the screw that secures the wireless-card bracket to the wireless card.
  46. Dell Alienware 13 R2 Camera Replacement, Align the Screw Holes: шаг 62, изображение 1 из 1
    • Align the screw holes on the hinge caps with the screw holes on the display hinges.
    • Replace the screws that secure the hinge caps to the display hinges.
  47. Dell Alienware 13 R2 Camera Replacement, Prying the Edges: шаг 64, изображение 1 из 1
    • Using your fingertips, carefully pry up the inside edges of the display bezel.
    • Carefully lift the display bezel and turn it over.
  48. Dell Alienware 13 R2 Camera Replacement, Lifting the Latches: шаг 66, изображение 1 из 1
    • Lift the connector latches and disconnect the display-board cables from the logo board.
  49. Dell Alienware 13 R2 Camera Replacement, Disconnect the Logo-Board Cable: шаг 67, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Disconnect the Logo-Board Cable: шаг 67, изображение 2 из 2
    • Disconnect the logo-board cable from the logo board.
  50. Dell Alienware 13 R2 Camera Replacement, Connect the Logo Board Cable: шаг 68, изображение 1 из 1
    • Connect the logo-board cable to the logo board.
  51. Dell Alienware 13 R2 Camera Replacement, Slide the Display-Board Cables: шаг 69, изображение 1 из 1
    • Slide the display-board cables to their respective connectors on the logo board and press down the latches to secure the cables.
    • Turn the display bezel over.
  52. Dell Alienware 13 R2 Camera Replacement, Align the Bezel: шаг 71, изображение 1 из 1
    • Align the display bezel with the display back-cover and gently snap the display bezel into place.
  53. Dell Alienware 13 R2 Camera Replacement, Remove the Screws: шаг 72, изображение 1 из 1
  54. Dell Alienware 13 R2 Camera Replacement, Lift the Display Panel: шаг 73, изображение 1 из 1
    • Gently lift the display panel and turn it over.
  55. Dell Alienware 13 R2 Camera Replacement, Disconnecting the Display Cable: шаг 74, изображение 1 из 2 Dell Alienware 13 R2 Camera Replacement, Disconnecting the Display Cable: шаг 74, изображение 2 из 2
    • Lift the connector latch and disconnect the display cable from the display panel.
  56. Dell Alienware 13 R2 Camera Replacement, Connect the Display Cable: шаг 75, изображение 1 из 1
    • Connect the NEW display cable to the display panel and press down on the connector latch to secure the cable.
    • Turn the display panel over.
  57. Dell Alienware 13 R2 Camera Replacement, Lifting the Latch: шаг 78, изображение 1 из 3 Dell Alienware 13 R2 Camera Replacement, Lifting the Latch: шаг 78, изображение 2 из 3 Dell Alienware 13 R2 Camera Replacement, Lifting the Latch: шаг 78, изображение 3 из 3
  58. Dell Alienware 13 R2 Camera Replacement, Securing the Cable: шаг 79, изображение 1 из 1
  59. Dell Alienware 13 R2 Camera Replacement, Align the Screw Holes: шаг 81, изображение 1 из 1
    • Align the screw holes on the display panel with the screw holes on the display back-cover.
  60. Dell Alienware 13 R2 Camera Replacement, Replace the Screws: шаг 82, изображение 1 из 1
    • Replace the screws that secure the display panel to the display back-cover.
  61. Dell Alienware 13 R2 Camera Replacement, Place on a Flat Surface: шаг 83, изображение 1 из 1
  62. Dell Alienware 13 R2 Camera Replacement, Disconnect the Camera Cable: шаг 84, изображение 1 из 1
    • Disconnect the camera cable from the camera module.
  63. Dell Alienware 13 R2 Camera Replacement, Prying the Camera Module: шаг 85, изображение 1 из 1
    • Using a plastic scribe, pry the camera module off the display back-cover.
  64. Dell Alienware 13 R2 Camera Replacement, Place the NEW Camera Module: шаг 86, изображение 1 из 1
    • Using the alignment posts place the NEW camera module on the display back-cover and snap it into place.
  65. Dell Alienware 13 R2 Camera Replacement, Connect the Camera Cable: шаг 87, изображение 1 из 1
    • Connect the camera cable to the camera module.
Заключение
Terrence15
Участник с: 12/18/17
79 091 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 119
