Dell Alienware 13 R2 Status-Light Board Replacement
Выберете то, что вам нужно
  1. Dell Alienware 13 R2 Status-Light Board Replacement, Turning Over the PC: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer After working inside your computer, follow the instructions in After Working Inside Your Computer For more safety best practices, see the regulatory compliance home page.
    • Close the display and turn the computer over.
  2. Dell Alienware 13 R2 Status-Light Board Replacement, Loosen the screws: шаг 2, изображение 1 из 1
    • Loosen the captive screws that secure the base panel to the computer base.
  3. Dell Alienware 13 R2 Status-Light Board Replacement, Releasing the Tabs: шаг 3, изображение 1 из 1
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  4. Dell Alienware 13 R2 Status-Light Board Replacement, Disconnecting the Battery Cable: шаг 4, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Disconnecting the Battery Cable: шаг 4, изображение 2 из 2
    • Disconnect the battery cable from the battery-cable connector.
    • Turn the computer over.
  5. Dell Alienware 13 R2 Status-Light Board Replacement, Power Button: шаг 5, изображение 1 из 1
    • Press and hold the power button for 5 seconds to ground the system board.
    • Connect the battery cable to the battery-cable connector.
  6. Dell Alienware 13 R2 Status-Light Board Replacement, Aligning the tabs: шаг 7, изображение 1 из 1
    • Align the tabs on the base panel with the slots on the computer base and snap the base panel into place.
  7. Dell Alienware 13 R2 Status-Light Board Replacement, Tighten the screws: шаг 8, изображение 1 из 1
    • Tighten the captive screws that secure the base panel to the computer base.
  8. Dell Alienware 13 R2 Status-Light Board Replacement, Removing the Screws: шаг 9, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Removing the Screws: шаг 9, изображение 2 из 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  9. Dell Alienware 13 R2 Status-Light Board Replacement, Peel off Computer Base Tabs: шаг 10, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Peel off Computer Base Tabs: шаг 10, изображение 2 из 2
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  10. Dell Alienware 13 R2 Status-Light Board Replacement, Disconnecting the Solid-State Drive Cable: шаг 11, изображение 1 из 1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  11. Dell Alienware 13 R2 Status-Light Board Replacement, Removing the Solid-State Drive: шаг 12, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Removing the Solid-State Drive: шаг 12, изображение 2 из 2
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  12. Dell Alienware 13 R2 Status-Light Board Replacement, Lifting the Solid-State Assembly: шаг 13, изображение 1 из 1
    • Lift the solid-state drive assembly off the computer base.
  13. Dell Alienware 13 R2 Status-Light Board Replacement, Remove the Screw: шаг 14, изображение 1 из 1
    • Remove the screw that secures the solid-state drive to the solid-state drive assembly.
  14. Dell Alienware 13 R2 Status-Light Board Replacement, Lift the Solid-State Assembly.: шаг 15, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Lift the Solid-State Assembly.: шаг 15, изображение 2 из 2
    • Slide and lift the solid-state drive off the solid-state drive assembly.
  15. Dell Alienware 13 R2 Status-Light Board Replacement, The New Solid-State Drive: шаг 16, изображение 1 из 1
    • Slide the NEW solid-state drive into the slot on the solid-state drive assembly.
  16. Dell Alienware 13 R2 Status-Light Board Replacement, Screw Replacement: шаг 17, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Screw Replacement: шаг 17, изображение 2 из 2
    • Replace the screw that secures the solid-state drive to the solid-state drive assembly.
  17. Dell Alienware 13 R2 Status-Light Board Replacement, Align the Screws: шаг 18, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Align the Screws: шаг 18, изображение 2 из 2
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  18. Dell Alienware 13 R2 Status-Light Board Replacement, Replace the Screws: шаг 19, изображение 1 из 1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  19. Dell Alienware 13 R2 Status-Light Board Replacement, Connect the Cable to the System Board: шаг 20, изображение 1 из 1
    • Connect the solid-state drive cable to the system board.
  20. Dell Alienware 13 R2 Status-Light Board Replacement, Align the Screw Holes: шаг 21, изображение 1 из 1
    • Align the screw holes on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  21. Dell Alienware 13 R2 Status-Light Board Replacement, Replace the Screws: шаг 22, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Replace the Screws: шаг 22, изображение 2 из 2
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  22. Dell Alienware 13 R2 Status-Light Board Replacement, Lifting the Latches: шаг 23, изображение 1 из 1
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board.
  23. Dell Alienware 13 R2 Status-Light Board Replacement, Remove the Screws: шаг 24, изображение 1 из 1
    • Remove the screws that secure the palm-rest assembly to the computer base.
  24. Dell Alienware 13 R2 Status-Light Board Replacement, Lift the Computer Base: шаг 25, изображение 1 из 1
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
    • Turn the computer over and open the display as far as possible.
  25. Dell Alienware 13 R2 Status-Light Board Replacement, Prying the Palm-Rest Assembly: шаг 27, изображение 1 из 1
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  26. Dell Alienware 13 R2 Status-Light Board Replacement, Lift the Palm-Rest Assembly: шаг 28, изображение 1 из 1
    • Gently lift the palm-rest assembly and turn it over.
  27. Dell Alienware 13 R2 Status-Light Board Replacement, Lift the Connector Latch: шаг 29, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Lift the Connector Latch: шаг 29, изображение 2 из 2
    • Lift the connector latch and disconnect the power-button board cable from the system board.
  28. Dell Alienware 13 R2 Status-Light Board Replacement, Lift the Palm-Rest Assembly: шаг 30, изображение 1 из 1
    • Lift the palm-rest assembly off the computer base.
  29. Dell Alienware 13 R2 Status-Light Board Replacement, Removing: шаг 31, изображение 1 из 1
    • Remove the keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the Touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
    • Connect the power-button board cable to the system board.
  30. Dell Alienware 13 R2 Status-Light Board Replacement, Align the Palm-Rest Assembly: шаг 34, изображение 1 из 1
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
  31. Dell Alienware 13 R2 Status-Light Board Replacement, Lift the Connector Latches: шаг 38, изображение 1 из 1
    • Lift the connector latches and disconnect the touchpad cable and the status-light cable from the power-button board.
  32. Dell Alienware 13 R2 Status-Light Board Replacement, Peel the Touchpad Cable: шаг 39, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Peel the Touchpad Cable: шаг 39, изображение 2 из 2
    • Peel the touchpad cable and status-light cable off the keyboard bracket.
  33. Dell Alienware 13 R2 Status-Light Board Replacement, Remove the Screws: шаг 40, изображение 1 из 1
    • Remove the screws that secure the keyboard bracket to the palm-rest assembly.
  34. Dell Alienware 13 R2 Status-Light Board Replacement, Lifting the Keyboard Bracket: шаг 41, изображение 1 из 1
    • Lift the keyboard bracket off the palm-rest assembly.
  35. Dell Alienware 13 R2 Status-Light Board Replacement, Remove the Screws: шаг 42, изображение 1 из 1
    • Remove the screws that secure the keyboard to the palm-rest assembly.
  36. Dell Alienware 13 R2 Status-Light Board Replacement, Slide and Lift the Keyboard: шаг 43, изображение 1 из 1
    • Slide and lift the keyboard, along with the cables, off the palm-rest assembly.
  37. Dell Alienware 13 R2 Status-Light Board Replacement, Align the Screw Holes: шаг 44, изображение 1 из 1
    • Align the screw holes on the NEW keyboard with the screw holes on the palm-rest assembly.
  38. Dell Alienware 13 R2 Status-Light Board Replacement, Replace the Screws: шаг 45, изображение 1 из 1
    • Replace the screws that secure the keyboard to the palm-rest assembly.
    • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
    • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
    • Adhere the touchpad cable and status-light cable to the keyboard bracket.
    • Slide the touchpad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
  39. Dell Alienware 13 R2 Status-Light Board Replacement, Disconnecting the Status-Light Board Cable: шаг 50, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Disconnecting the Status-Light Board Cable: шаг 50, изображение 2 из 2
    • Lift the connector latch and disconnect the status-light board cable from the status-light board.
  40. Dell Alienware 13 R2 Status-Light Board Replacement, Remove the Screw: шаг 51, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Remove the Screw: шаг 51, изображение 2 из 2
    • Remove the screw that secures the status-light board to the palm-rest assembly.
    • Lift the status-light board off the palm-rest assembly.
  41. Dell Alienware 13 R2 Status-Light Board Replacement, Sliding the Cable: шаг 53, изображение 1 из 2 Dell Alienware 13 R2 Status-Light Board Replacement, Sliding the Cable: шаг 53, изображение 2 из 2
    • Slide the status-light board cable into the status-light board connector and press down the latch to secure the cable.
  42. Dell Alienware 13 R2 Status-Light Board Replacement, Align the Screw Hole: шаг 54, изображение 1 из 1
    • Align the screw hole on the status-light board with the screw hole on the palm-rest assembly.
  43. Dell Alienware 13 R2 Status-Light Board Replacement, Replace the Screw: шаг 55, изображение 1 из 1
    • Replace the screw that secures the status-light board to the palm-rest assembly.
Заключение
Terrence15
Участник с: 12/18/17
79 121 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 986 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 105
