Dell Alienware 14 Secondary Hard Drive Replacement
Выберете то, что вам нужно
  1. Dell Alienware 14 Secondary Hard Drive Replacement, Close the Display: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Secondary Hard Drive Replacement, Remove the Screws: шаг 2, изображение 1 из 2 Dell Alienware 14 Secondary Hard Drive Replacement, Remove the Screws: шаг 2, изображение 2 из 2
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Secondary Hard Drive Replacement, Slide and Lift the Base Cover: шаг 3, изображение 1 из 1
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Secondary Hard Drive Replacement, Align the Tabs: шаг 4, изображение 1 из 1
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Secondary Hard Drive Replacement, Replace the Screws: шаг 5, изображение 1 из 1
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Secondary Hard Drive Replacement, Turn the Computer Over: шаг 6, изображение 1 из 1
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Secondary Hard Drive Replacement, Disconnecting the Battery Cable: шаг 7, изображение 1 из 1
  8. Dell Alienware 14 Secondary Hard Drive Replacement, Remove the Screws: шаг 8, изображение 1 из 1
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Secondary Hard Drive Replacement, Using the Battery Cable: шаг 9, изображение 1 из 1
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Secondary Hard Drive Replacement, Turn the Computer Over: шаг 10, изображение 1 из 1
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Secondary Hard Drive Replacement, The Power Button: шаг 11, изображение 1 из 1
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Secondary Hard Drive Replacement, Align the Tabs: шаг 13, изображение 1 из 1
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Secondary Hard Drive Replacement, Align the Screw Holes: шаг 14, изображение 1 из 1
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Secondary Hard Drive Replacement, Replace the Screws: шаг 15, изображение 1 из 1
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Secondary Hard Drive Replacement, Connect the Battery Cable: шаг 16, изображение 1 из 1
    • Connect the battery cable to the system-board connector.
  16. Dell Alienware 14 Secondary Hard Drive Replacement, Remove the Screws: шаг 17, изображение 1 из 2 Dell Alienware 14 Secondary Hard Drive Replacement, Remove the Screws: шаг 17, изображение 2 из 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • NOTE: The secondary hard-drive or solid-state drive is optional and can be installed in the optical drive bay.
    • Remove the screws that secure the secondary hard-drive assembly to the computer base.
  17. Dell Alienware 14 Secondary Hard Drive Replacement, Lifting the Secondary Hard-Drive: шаг 18, изображение 1 из 3 Dell Alienware 14 Secondary Hard Drive Replacement, Lifting the Secondary Hard-Drive: шаг 18, изображение 2 из 3 Dell Alienware 14 Secondary Hard Drive Replacement, Lifting the Secondary Hard-Drive: шаг 18, изображение 3 из 3
    • Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
  18. Dell Alienware 14 Secondary Hard Drive Replacement, Lifting the Hard Drive: шаг 19, изображение 1 из 1
    • Lift the secondary hard-drive assembly off the computer base.
  19. Dell Alienware 14 Secondary Hard Drive Replacement, Turn the Assembly Over: шаг 20, изображение 1 из 1
    • Turn the secondary hard-drive assembly over.
  20. Dell Alienware 14 Secondary Hard Drive Replacement, Remove the Screw: шаг 21, изображение 1 из 1
    • Remove the screw that secures the secondary hard-drive assembly to the main bracket.
  21. Dell Alienware 14 Secondary Hard Drive Replacement, Remove the Screws: шаг 22, изображение 1 из 1
    • Remove the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  22. Dell Alienware 14 Secondary Hard Drive Replacement, Slide and Lift the Hard-Drive: шаг 23, изображение 1 из 2 Dell Alienware 14 Secondary Hard Drive Replacement, Slide and Lift the Hard-Drive: шаг 23, изображение 2 из 2
    • Slide and lift the secondary hard-drive off the secondary hard-drive bracket.
  23. Dell Alienware 14 Secondary Hard Drive Replacement, Disconnect the Interposer: шаг 24, изображение 1 из 2 Dell Alienware 14 Secondary Hard Drive Replacement, Disconnect the Interposer: шаг 24, изображение 2 из 2
    • Disconnect the interposer from the secondary hard-drive connector.
  24. Dell Alienware 14 Secondary Hard Drive Replacement, Connect the Interposer: шаг 25, изображение 1 из 1
    • Connect the interposer to the secondary hard-drive connector.
  25. Dell Alienware 14 Secondary Hard Drive Replacement, Placing the Secondary Hard-Drive: шаг 26, изображение 1 из 1
    • Place the NEW secondary hard-drive in the secondary hard-drive bracket.
  26. Dell Alienware 14 Secondary Hard Drive Replacement, Align the Screw Holes: шаг 27, изображение 1 из 1
    • Align the screw holes on the secondary hard-drive with the screw holes on the secondary hard-drive bracket.
  27. Dell Alienware 14 Secondary Hard Drive Replacement, Replace the Screws: шаг 28, изображение 1 из 1
    • Replace the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  28. Dell Alienware 14 Secondary Hard Drive Replacement, Align the Screw Hole: шаг 29, изображение 1 из 1
    • Align the screw hole on the secondary hard-drive assembly with the screw hole on the main bracket.
  29. Dell Alienware 14 Secondary Hard Drive Replacement, Replace the Screw: шаг 30, изображение 1 из 1
    • Replace the screw that secures the secondary hard-drive assembly to the main bracket.
  30. Dell Alienware 14 Secondary Hard Drive Replacement, Turn the Hard-Drive Assembly Over: шаг 31, изображение 1 из 1
  31. Dell Alienware 14 Secondary Hard Drive Replacement, Slide the Hard-Drive Cable: шаг 32, изображение 1 из 1
    • Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
  32. Dell Alienware 14 Secondary Hard Drive Replacement, Align the Screw Holes: шаг 33, изображение 1 из 1
    • Align the screw holes on the secondary hard-drive assembly with the screw holes on the computer base.
    • Replace the screws that secure the secondary hard-drive assembly to the computer base.
Заключение
Еще один человек закончил это руководство.
Terrence15
Участник с: 12/18/17
79 121 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 2,098
