Введение
If you need to replace the Wi-Fi card from your Dell Alienware 15 R3, follow this guide.
Выберете то, что вам нужно
Flip the laptop over so that the backside is facing up.
Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
Use the opening tool to pry the back case from the computer.
Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
Lift the back case off of the laptop.
Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
Use a Phillips #00 screwdriver to remove nine screws from the chassis.
Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
Open the flap to reveal the Wi-Fi card.
Use the Phillips #00 screwdriver to remove the screw securing the Wi-Fi card.
Use a spudger to detach the coaxial cables from the Wi-Fi card.
