Dell Alienware M17x R3 Hard Drive Replacement
Выберете то, что вам нужно
  1. Dell Alienware M17x R3 Hard Drive Replacement, Loosen the Captive Screws: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Loosen the three captive screws that se cure the hard-drive assembly to the computer base.
  2. Dell Alienware M17x R3 Hard Drive Replacement, Lifting the Hard-Drive: шаг 2, изображение 1 из 1
    • Using the pull-tab, lift the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Alienware M17x R3 Hard Drive Replacement, Lifting the Hard-Drive Assembly: шаг 3, изображение 1 из 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Alienware M17x R3 Hard Drive Replacement, Remove the Screws: шаг 4, изображение 1 из 1
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  5. Dell Alienware M17x R3 Hard Drive Replacement, Lifting the Hard-Drive: шаг 5, изображение 1 из 1
    • Lift the hard-drive off the hard-drive bracket.
  6. Dell Alienware M17x R3 Hard Drive Replacement, Remove the Interposer: шаг 6, изображение 1 из 1
    • Remove the interposer from the hard drive.
  7. Dell Alienware M17x R3 Hard Drive Replacement, Connecting the Interposer: шаг 7, изображение 1 из 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Alienware M17x R3 Hard Drive Replacement, Placing the Hard Drive: шаг 8, изображение 1 из 2 Dell Alienware M17x R3 Hard Drive Replacement, Placing the Hard Drive: шаг 8, изображение 2 из 2
    • Place the hard drive in the hard-drive bracket.
  9. Dell Alienware M17x R3 Hard Drive Replacement, Replace the Screws: шаг 9, изображение 1 из 1
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  10. Dell Alienware M17x R3 Hard Drive Replacement, Align the Connector: шаг 10, изображение 1 из 1
    • Align the connector on the hard drive with the connector on the system board and press the hard drive until it is fully seated.
  11. Dell Alienware M17x R3 Hard Drive Replacement, Tighten the Screws: шаг 11, изображение 1 из 1
    • Tighten the three captive screws that secure the hard-drive assembly to the computer base.
Заключение
Terrence15
Участник с: 12/18/17
79 131 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 986 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 1,241
