Введение
In this guide, we will show you how to remove and replace the Memory Modules.
Выберете то, что вам нужно
Remove the screws that secure the memory-module cover to the palm rest assembly.
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Remove the memory module from the memory-module connector.
Align the notch in the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Align the screw holes on the memory-module cover with the screw holes on the palm rest assembly.
Replace the screws that secure the memory-module cover to the palm rest assembly.
