Введение
The battery is a very common part to need to replace on a computer, especially as it becomes older. This is a very straightforward process and will only require removing a few screws and unplugging a cable. It should only take a couple of minutes, and there is little damage to be done.
Выберете то, что вам нужно
Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
Using a plastic opening tool, begin to separate the back cover from the body of the computer.
Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
Using a Phillips #0 screwdriver, remove each of the three 3mm screws from the battery.
8 участников успешно повторили данное руководство.
