Dell Chromebook 11 3180 Keyboard Replacement
Выберете то, что вам нужно
  1. Dell Chromebook 11 3180 Keyboard Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Keyboard Replacement: шаг 2, изображение 1 из 1
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Keyboard Replacement: шаг 3, изображение 1 из 1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Keyboard Replacement: шаг 4, изображение 1 из 1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Keyboard Replacement: шаг 5, изображение 1 из 1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Keyboard Replacement, Keyboard: шаг 6, изображение 1 из 1
    • Disconnect the ribbon cable from the motherboard. To do this, lift up the black tab hinge securing the ribbon cable and pull the cable up and then out of the port.
  7. Dell Chromebook 11 3180 Keyboard Replacement: шаг 7, изображение 1 из 1
    • Release the keyboard from the body. To do this, push on the two keyboard release holes with something thin and cylindrical like a spudger or a pencil.
  8. Dell Chromebook 11 3180 Keyboard Replacement: шаг 8, изображение 1 из 1
    • Remove the keyboard from the body. To do this, use a plastic prying tool to get under the keyboard and pry it up from the computer body.
  9. Dell Chromebook 11 3180 Keyboard Replacement: шаг 9, изображение 1 из 1
    • Once you have separated the keyboard and the body using a spudger or plastic opening tool, use your hands to pull it away from and off of the computer.
Заключение
13 участников успешно повторили данное руководство.
Devon Paul
Участник с: 04/26/17
1 206 Репутация
Автор 6 руководств
Команда
Cal Poly, Team S22-G1, Livingston Spring 2017 Участник Cal Poly, Team S22-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G1
4 членов
Автор 8 руководств
Один комментарий
How I will fix the chromebook 11 now?
Federico Vazquez - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 24
За всё время: 7,311
