Введение
This guide will show you how to replace the speakers of your Chromebook. This is a very straightforward and easy repair.
Выберете то, что вам нужно
Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
Using a plastic opening tool, begin to separate the back cover from the body of the computer.
Locate and gently pull the wire harness (small plastic box with wires leading to black audio speakers) directly out of the connector on the motherboard.
Remove any existing tape attached to the audio wire you unplugged in the previous step.
Gently lift and remove speakers.
3 участников успешно повторили данное руководство.
