Введение
This guide will show you how to replace the fan. It is very common for a fan to collect dust, and without proper cooling, a device may overheat and suffer permanent internal damage. Knowing how to remove a fan for proper cleaning can be beneficial for the condition and longevity of a laptop.
Инструменты
Запчасти
Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
Locate the two wires that connect the fan to the device. One black, and one white.
Move these wires off of the fan by gently pulling on them.
Locate the two 8mm Philips #0 screws that connect the fan to the device.
Remove these screws using a Philips #0 screwdriver.
The fan is connected by a 5 pin port. Remove this by gently prying out the fan's port using your fingers or a plastic prying tool.
