Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
Locate the two wires that connect the fan to the device. One black, and one white.
Move these wires off of the fan by gently pulling on them.
Locate the two 8mm Philips #0 screws that connect the fan to the device.
Remove these screws using a Philips #0 screwdriver.
The fan is connected by a 5 pin port. Remove this by gently prying out the fan's port using your fingers or a plastic prying tool.
