Dell Chromebook 11 CB1C13 Letter & Number Key Replacement
Выберете то, что вам нужно
    • Check the 4 metal clips that are attached to the palmrest. Look for damaged or missing clips.
    • If any of the 4 clips are missing, you will not be able to proceed and will have to replace the entire palmrest.
    • Check the condition of the rubber spring/membrane. If it is torn or missing, you will not be able to proceed and will have to replace the entire palmrest.
    • If any clips are bent, carefully use your tweezer to bend them back in their original upright position. (See video)
    Спросите у FixBot
    Добавить комментарий
  1. Dell Chromebook 11 CB1C13 Letter & Number Key Replacement, Check Plastic Bracket: шаг 2, изображение 1 из 1
    • Check the plastic bracket for damage in these 6 areas.
    Спросите у FixBot
  2. Dell Chromebook 11 CB1C13 Letter & Number Key Replacement, Check Key for damage: шаг 3, изображение 1 из 1
    • Check the 4 main points of the key for damage.
    • Any damage in these areas will not allow the key to stay connected to the plastic bracket which sits underneath the key
    Спросите у FixBot
  3. Инструмент, используемый на этом этапе:
    • While using tweezers, remove just the actually key (top layer only) . You want to try and remove the key without also removing the plastic bracket that sits right underneath the key.
    • Try to slightly pick at the corner of the key. This helps remove the key separately from the plastic bracket.
    Спросите у FixBot
    • With tweezers, carefully start picking near the four corners where the 4 metal clips are securing the plastic bracket.
    Спросите у FixBot
    • Line up the 2 outer corners and the bottom inner corners of the plastic bracket with the 4 metal clips connected to the palmrest.
    Спросите у FixBot
    • Place the key on top of the plastic bracket and press down. If the plastic bracket is on correctly and securely, the key should easily snap into place.
    • Check if the key is secure by tapping around all sides of the key. This is a good test to make sure the metal clips are properly securing the plastic bracket and making sure that the plastic bracket can hold the key correctly.
    Спросите у FixBot
Заключение
7 человек успешно провели ремонт по этому руководству.
Jon
Участник с: 08/18/13
3 972 Репутация
Автор 22 руководств
6 Комментарии к руководству
thanks this helped a lot and fixed my Chromebook thanks.
Jaxson Cowell - Ответить Поделиться
Glad to hear it helped Jaxson! I appreciate the positive feedback.
Jon - Ответить Поделиться
I accidentally broke my chromebook from school and the plastic bracket is damaged, what should I do?
Jud Franks - Ответить Поделиться
the plastic brackets are correctly intact but whenever i go to put the key it doesnt work and the key isnt damaged
Random Deku - Ответить Поделиться
nvm the key just got in and the my chromebook is fixed
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 14
За последние 30 дней: 55
За всё время: 13,405
