Dell Chromebook 11 CB1C13 Special Key Replacement
Выберете то, что вам нужно
    1. Инструмент, используемый на этом этапе:
      • Unlike letter and number keys, some "special keys" have 2 sets of metal clips. Plus, a stabilizer holder on both sides.
      • If you notice that one of the metal clips or stabilizer holders is bent, carefully use your tweezers to bend back into an upright position.
      Спросите у FixBot
      Добавить комментарий
    2. Dell Chromebook 11 CB1C13 Special Key Replacement, Check Plastic Brackets: шаг 2, изображение 1 из 1
      • Check the plastic brackets for damage in these areas.
      Спросите у FixBot
    3. Dell Chromebook 11 CB1C13 Special Key Replacement, Check Key for damage: шаг 3, изображение 1 из 1
      • Check the 8 main points of the key on the inside of the key for damage.
      • Check to make sure the stabilizer (bar) is present and the 3 clips that secure it to the key are not damaged.
      • Any damage in these areas will not allow the key to stay connected to the plastic bracket which sits underneath the key.
      Спросите у FixBot
      • While using tweezers, remove just the actual key (top layer only) . You want to try and remove the key without also removing the plastic bracket that sits right underneath the key.
      • Try to slightly pick at the corner of the key. This helps remove the key separately from the plastic bracket.
      • Don't forget that these "special keys" have a stabilizer (bar) underneath the key.
      Спросите у FixBot
      • With tweezers, carefully start picking near the four corners where the 4 metal clips are securing the plastic bracket. Remember these special keys have 2 plastic brackets to remove.
      Спросите у FixBot
      • Line up the 2 outer corners and the bottom inner corners of the plastic bracket with the 4 metal clips connected to the palmrest.
      • Repeat this step as there are 2 plastic brackets for both shift keys, spacebar, and Alt key (left of spacebar).
      Спросите у FixBot
      • First line up the stabilizer ends with the stabilizer holders and slide each end through the stabilizer holders connected to the palmrest.
      • Place the key on top of the plastic bracket and press down. If both plastic brackets are on correctly and securely, the key should easily snap into place.
      • Check if the key is secure by tapping around all sides of the key. This is a good test to make sure the metal clips are properly securing the plastic bracket, the stabilizer, and making sure that the plastic bracket can hold the key correctly.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Jon
Участник с: 08/18/13
3 972 Репутация
Автор 22 руководств
2 Комментарии к руководству
Where is spacebar replacment guid? Please me keyboard hurnt
Carl Schiefer - Ответить Поделиться
I do not have a separate spacebar guide but it is repaired just like all the other “special keys” as you see in this guide. The only difference is that it has 2 metal bars located under the key.
Jon - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 13
За последние 7 дней: 31
За последние 30 дней: 68
За всё время: 6,459
