Dell Chromebook 11-3120 Motherboard Replacement
Выберете то, что вам нужно
  1. Dell Chromebook 11-3120 Motherboard Replacement, Back Panel: шаг 1, изображение 1 из 2 Dell Chromebook 11-3120 Motherboard Replacement, Back Panel: шаг 1, изображение 2 из 2
    • Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
  2. Dell Chromebook 11-3120 Motherboard Replacement: шаг 2, изображение 1 из 2 Dell Chromebook 11-3120 Motherboard Replacement: шаг 2, изображение 2 из 2
    • Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
    • Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
  3. Dell Chromebook 11-3120 Motherboard Replacement, Battery: шаг 3, изображение 1 из 2 Dell Chromebook 11-3120 Motherboard Replacement, Battery: шаг 3, изображение 2 из 2
    • Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
  4. Dell Chromebook 11-3120 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Using the pointed end of a #2 spudger, remove the connection between the battery and motherboard by slightly pulling on the wires while pushing the tiny hole down using the spudger.
    • Pull out the battery from inside the laptop.
  5. Dell Chromebook 11-3120 Motherboard Replacement, Motherboard: шаг 5, изображение 1 из 2 Dell Chromebook 11-3120 Motherboard Replacement, Motherboard: шаг 5, изображение 2 из 2
    • Using a JIS #0 screwdriver, unscrew the ten 4mm screws securing the motherboard in place.
  6. Dell Chromebook 11-3120 Motherboard Replacement: шаг 6, изображение 1 из 2 Dell Chromebook 11-3120 Motherboard Replacement: шаг 6, изображение 2 из 2
    • Gently remove the 3 ribbon cables that connect to the motherboard from other components. Lift the tiny switch from the direction of the wire insertion keeping the ribbon in place and pull the transparent strip attached to the ribbon.
    • Gently remove the display ribbon cable that says "NON-TOUCH" on its tag. This ribbon cable does not have a locking switch, but there is a wire metal latch that should be lifted up before pulling the ribbon.
    • Use caution when removing ribbon cables as they may tear if too much force is used.
    • Please mind that if the ribbon cable port has a locking switch, you must unlock this prior to pulling out the cable. Failure to do so can damage the port and make it difficult to remain inserted.
  7. Dell Chromebook 11-3120 Motherboard Replacement: шаг 7, изображение 1 из 2 Dell Chromebook 11-3120 Motherboard Replacement: шаг 7, изображение 2 из 2
    • Remove the two 4-pin connectors that are also connected from other components in the device. Gently tug on the connector and it will come loose.
  8. Dell Chromebook 11-3120 Motherboard Replacement: шаг 8, изображение 1 из 2 Dell Chromebook 11-3120 Motherboard Replacement: шаг 8, изображение 2 из 2
    • Disconnect the small chip that connects to the motherboard by gently tugging on it in the direction away from the board.
  9. Dell Chromebook 11-3120 Motherboard Replacement: шаг 9, изображение 1 из 1
    • Hold the sides of the motherboard and gently lift it upwards from its position.
    • Be careful not to tug on any cables that may snag onto the board as you lift. Keep clear before lifting.
Заключение
5 участников успешно повторили данное руководство.
Joseph Pumphrey
Участник с: 10/19/17
335 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team S4-G1, Julie Fall 2017 Участник UMass Dartmouth, Team S4-G1, Julie Fall 2017
UMASSD-JULIE-F17S4G1
3 членов
Автор 6 руководств
Один комментарий
Battery removal isn’t necessary. After removing the bottom case, you can skip to step 4 and just disconnect the battery before continuing.
Random Tech - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 2,005
