Введение
A damaged motherboard is a serious issue and can be a hassle to fix, but it doesn't have to be! By following the quick and easy motherboard replacement guide you can have your Chromebook working again in no time!
Выберете то, что вам нужно
Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
To remove the battery, lift up on one side to get your fingers underneath and lift away.
Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
Один комментарий
Is it possible to swap the non-touch matte display and the glossy touchscreen on two Dell Chromebook 13 7310?
