Введение
Use this guide to replace your broken web cam with a new one to get reconnected face-to-face with your friends and family!
Выберете то, что вам нужно
To remove the screen, start by using the black nylon spudger to pry off the plastic hinge cover. This allows easy removal of the screen cover.
Using the same spudger and your finger nails, gently pry the outer casing around the screen itself. Once it is 1/3 to 1/2 of the way removed, gently pull the rest free by hand.
Once the clips are undone, remove the cover and you are ready for the next step!
Now that the camera is exposed, disconnect the wire by hand to untether the camera unit from the motherboard.
To disconnect, pull to the straight back from the camera connection point.
Once you have disconnected the camera, use the small nylon pry bar to dislodge the camera assembly from the computer housing.
After the camera assembly is free from the backing plate, remove it from the housing bay hand.
Congratulations! You have successfully removed the web camera of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
