Введение
In the case that the screen on your Dell Chromebook 3100 2-in-1 doesn’t show anything or the touch display is unresponsive, your laptop may have a faulty screen.
Note: Some Dell Chromebook 3100 configurations don’t have a touch screen.
Выберете то, что вам нужно
Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
Remove the adhesive tape that secures the battery in place.
Remove the single 3 mm screw that secures the WLAN bracket to the system board using a Phillips #1 screwdriver.
Lift the WLAN bracket from the system board.
After lifting the bracket, carefully unplug the two coaxial cables.
Remove the single 4 mm screw that secures the eDP bracket to the motherboard using a Phillips #1 screwdriver.
Remove the eDP bracket.
Disconnect the display cable from the motherboard by using a plastic opening pick.
Open the system to 180 degrees and place the computer on a flat surface, with the display hinges facing up.
Remove the three (on both hinges) 5 mm display hinge bracket screws that secure the display assembly to the system using a Phillips #1 screwdriver.
Use the opening tool to open the display panel starting from the pry points located above the left and right hinges.
Work your way around, through the left and right side of the panel, and carefully flip the display panel over.
Peel back the adhesive tape securing the display cable on the back of the display panel and separate the display.
Еще один человек закончил это руководство.
