Введение
Follow this guide to remove and replace the motherboard in the Dell Chromebook 3100 2-in-1 laptop.
For your safety, discharge your battery below 25% before disassembling it. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Выберете то, что вам нужно
Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
Remove the adhesive tape that secures the battery in place.
Remove adhesive tape that secures the speaker cable.
Disconnect the speaker cable from the connector on the system board.
Remove the single 3 mm screw that secures the WLAN bracket to the system board using a Phillips #1 screwdriver.
Lift the WLAN bracket from the system board.
After lifting the bracket, carefully unplug the two coaxial cables.
Remove the single 4 mm screw that secures the eDP bracket to the motherboard using a Phillips #1 screwdriver.
Remove the eDP bracket.
Disconnect the display cable from the motherboard by using a plastic opening pick.
Remove the five 4 mm screws that secure the motherboard using a Phillips #1 screwdriver.
4 участников успешно повторили данное руководство.
