Введение
This guide will tell you step-by-step how to replace the webcam in the Dell Chromebook 3100 2-in-1.
Before beginning, make sure to power off your phone completely and disconnect from any external power source.
Выберете то, что вам нужно
Using a Phillips screw driver (PH1) remove the 9 (M2.5x4) screws holding the back cover
Remove the single screw (M2x3).
Remove the bracket over the Wi-Fi and camera plugs.
Remove the 6 screws (M2.5x5) holding the hinges on both ends.
When both brackets are free, separte the screen from the computer screen from the bottom section.
