Введение
If your screen is cracked or not functioning correctly, follow this guide.
Выберете то, что вам нужно
First, disassemble the device, taking off the top and bottom panels. See the disassembly guide for further directions.
Slide the internal components out of the case.
If the device has a lot of dirt on the internal components, this may be the cause of the screen malfunction. Reassemble device at this point to see if it has fixed the problem.
Disconnect side clips of screen to detach the base of it from the main circuit board, using the metal spudger.
To replace, purchase a new screen and locate the small silver bar located on the motherboard.
Insert the end of the new screen into the opening of the silver bar, securing it in there to hold your new screen.
After the device is assembled, power the device on. The issue should be repaired.
If the device screen is still defective, an issue with the motherboard or a greater malfunction could be the cause.
